Case 3pt. Blades ?
Am looking at a 3 pt. blade that the owner says is a Case brand. Could someone post the models or styles that were Case before the Danuser Haus models? Want to hook it up to my VAC, it has a spring loaded pin without the extended handle, and it's blade is 6'. Thanks, Mike
(quoted from post at 22:37:20 07/21/14) Am looking at a 3 pt. blade that the owner says is a Case brand. Could someone post the models or styles that were Case before the Danuser Haus models? Want to hook it up to my VAC, it has a spring loaded pin without the extended handle, and it's blade is 6'. Thanks, Mike
Here is the first Case Danuser Blade Model G-16 made for Case Eagle Hitch tractors.
Here's the next generation made for 3pt or eagle hitch G-16A
Here's the serial tags, on the G-16A
Here's a pic of my Stockland brand blade that was sold new with my Case 411 through the Case Dealer
Here is the cover page for a brochure on the New Case VAI with eagle hitch showing a similar Stockland blade.
If you can post a picture it would help. These are the only Case blades I am familiar with. There may have been some later on that are Case/IH. Nick
Nick, you need a bearing cover for this girl.
Clean her out and repack the bearings, Danuser
still sells many parts for these blades, I bet
this is one they still sell.
I sure wish I could find a Case/Danuser 8 footer.
I have a Danuser made to hook to conventional 3pt
that I adapted to Eagle hitch but I didn't try to
duplicate the 3 position side tilt feature for
ditch and terrace work.
Jim
(quoted from post at 07:38:53 07/22/14) Nick, you need a bearing cover for this girl.
Jim
Jim, where do you go for parts? I called my CASE dealer who used to sell these and they gave me the number of the Danuser dealer who carried repair parts and they no longer could get anything for those blades. I have a 6' with a scarifier and needed bearings and a cap and found the cap in the parts depot. Bearings are the same as a Ford truck front wheels.
