Hi All,
I recently inherited a case 580Ck, Serial #8340435. With a backhoe attached. Could anyone explain the starting procedure particularly how the block heater works, and also the switch that says start and heat. How should the block heater light work, Im not sure things are working the way they should. I have used other newer tractors where I turned the keyswitch part way until the block heater light went out then started the tractor. Any info about this case would be very helpfull, such as where I might find parts for this model. Thanks
