Case 870 powershift
This year when baling hay with 870 I noticed when I put it in reverse it makes a squealing and lurches some. I bale in 3-1 or 3-2. I notice this worst in 3-R. 1-R is fine. Backing the baler in the shed is kinda a jumpy project in 3-R . The forward speeds shift great in all ranges.
What do you think?
First off, 3rd reverse is a pretty high gear for backing a peice of equipment into a shed. First range reverse would be more sensable. All the power shifts have a whine in reverse, and more noticable in the higher ranges.
Also when backing up, plant your heel on the floorboard and bend your foot to feather the inching spool.
Loren.
Dan: You sure do travel when baling!! Agree w/ Loren 100%. When backing, to insure long life of the tranny, idle down & gear down, there-by reducing or eliminating slippage.
cab mounts are very touchy indeed. maybe should change mine ,,,can anyone give me a rule of thumb measure as to when they need attention ?? serveral yrs ago . I backed out at a angle from a lean to ,, and like to run off with the whole damshed ! when the cab brushed against the mainsupport beam , no clutch and reved the throttle ! nuthin responded except for kill switch!... thank gawd ,.in the past had pulled straight in and out no problem , oh yeah ,, just got the junkyard dawg 1070 and I had to air the slowleak rear tire each time I used it,,.kinda made it taller ,, lol,,. boy-o-boy!.. case likes to go backwards FAST,,.my 800,730 and early 1070 ggoes way to fast for me... btw ,,.if a guy ever injures his rite hand /arm or has rotater cup problems ,(like I did) , all those control levers on the rite need oiled up with wd-40 ,, that helps a lot ... also don't know if anyone else has tried this,at my sons suggestion... i painted the rangeshift levers RED the p/s levers Orange , and the throttle Yellow . pto lever also RED.. 3 pt lever I painted lime green... color coding the power groups helps us slip seaters around here who don't drive the 1070 but a few times a year ...
