More 1160 work
jon f mn
Had to partially disassemble the header drive clutch too to get it loose. As bad as the drive clutch was to take apart, this was easy. To replace the clutch disc all you have to do is remove that outer ring and the disc comes out in 3 pieces so you don't have to take the assy apart to repair it. As far as I'm concerned, they should have made the drive clutch easier instead, but that's why they get the big bucks.
