Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: PTO on DB 990
Adirondack case guy
07-17-2014 14:39:09
Sir,
High on the PTO is 1000RPM. Your baler is a 540RPM machine. Why did you chose the 1000RPM speed?
I have been following your posts for the last two months about this 990 you bought, and to be very truthful with you,, YOU are a person whom should never own a tractor because you know nothing about them.
You would have been far further ahead, financially and mentally, if you hired someone to make your hay.
I know this is Blunt, but!!!!
Loren
MJ in the UK
07-18-2014 02:43:29
 Re: PTO on DB 990 in reply to Adirondack case guy, 07-17-2014 14:39:09
I agree 100% with Loren, by using it in the 1000rpm PTO i would think you have burnt the clutch out. I sold David Brown tractors in the 1960s and still repair them for a living and have great respect for them. Get an operators manual and READ IT THREE TIMES before you get back on the tractor seat before you ruin the tractor. MJ
Farmallb
07-17-2014 15:17:23
Well, ive had my granddads CC Case and have drove it since I was 8.
I have a 48 H Farmall that ive had for around 5yrs without a bit of problem.
I have a 1950 Demonstrator Cub Farmall that ive had for around 6yrs with no problem.
My problem is, likely, that ive never had experience with a tractor with a 2 stage clutch, or with 3pt hookup, or with diesel, and all that goes along with diesel.
Adirondack case guy
07-17-2014 16:32:38
 Re: PTO on DB 990 in reply to Farmallb, 07-17-2014 15:17:23
Bare with my critisum.
I was turned loose with a Case model L at 8yrs. old.
Those tractors at that time furnished belt power, not PTO power.
When you drove the Farmall H, you were lucky if you had one with a 1-3/8" 540 PTO shaft. What PTO implement did you run with it.
You may have started young, but you seam to have a gap in your farming experience. All of us here who have replied to your posts will likely still try to help you with your dilemas, but you need to step up with some common sence also.
Have you aquired an opp. manual for your 990, and sat down and read it yet?
It aint no CC, with 3 forward gears and a hand clutch.
Loren
Copyright © 1997-2015 Yesterday's Tractor Co.
