Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
SC Block Breakage, Was This Very Common?
1370rod
07-16-2014 21:45:46
A very nicely restored SC needed head work and then I found these cracks. Broken between every cyl. We will put the head back on and keep our fingers crossed as the unit is used for parades and shows. Rod.
B A Star
07-17-2014 18:29:56
 Re: SC Block Breakage, Was This Very Common? in reply to 1370rod, 07-16-2014 21:45:46
   I have been around a several brands of engines.  When In seeing crankcases that are cracked in the manner this one is it means that it had a coolant mixture that was too weak.  When it freezes and expands it puts too much pressure on the sidewalls of the crankcase.   Think about how many sq. in of surfaces you have on the sides of the crankcase, as it pushes it stretches the small area between the cylinder bores and it splits em.  Too little or no antifreeze in the coolant system.
1031D
07-17-2014 07:28:39
Paint some copper coat on the head gasket and forget about it! I have some tractors on the farm like dad's Allis C and a VAC that are this way, have been in farm use for over a decade.
John Saeli
07-17-2014 06:25:19
3-11/16" Dome Pistons? Might be a give-a-way that she was asked more to do than she was designed for. I have never seen a crack in an SC Block.
casecollectorsc
07-17-2014 05:39:11
Never saw a SC cracked like that but took the head off a DC that was split 1/16" open down the center like that. Assumed it had been frozen.
Adirondack case guy
07-17-2014 05:29:37
The 148 that I am rebuilding for my 310 dozer has the same issue. I'm not worried about it.
Loren
wheat straw
07-17-2014 04:12:07
don't know about the sc but not unusual on a vac and the head gasket seals it off with no issues even under heavy use.
Andy
