870 Ugly Duckling has now become a Swan
Eddie7295
After a transmission overhaul, motor overhaul, PTO overhaul, new hydraulic pump, powershift valve, a paint job, it is finally done!
nice looking tractor, you did a good job. Always feels good when they are finally done. what kind of Oliver do you have in the background? looks like it has ROPS/Canopy and fender fuel tanks?
Very nice, darn nice tractor that will treat you well. Looks like a turbo ex manifold, is she running on a little boost? Rod.
Yes center and end section off a 504 capped the end. We used a T0 4b 80 air research turbo that was originally off a 7010 allis with the 301 engine. This thing is my 18 year old sons tractor we did the work ourselves, after break in she has a date with a Dyno the goal. Is 100 hp.
This is a 71 model my son likes the white over the desert sunset color all the white and black is powder coat paint the front fiberglass piece is wet paint. Someone before had painted it white.
Very Nice!! One of the greatest tractors to ever leave a factory, the Famed 870!! Rugged enough to dual up & fit ground all Spring, or handy enough to go cut hay with. I cut thousands of acres of hay w/ a 540 PTO haybine, using the 1,000 PTO on the 870 & an adapter, & never seeing the fuel gauge move.
