Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Case 2090 Float Control
dbeam
07-16-2014 15:17:53
A client of mine has a case 2090 and is complaining of the float control not staying engaged on its own. I have limited experience with this but I am assuming that the float control is supposed to stay locked in float when ever the lever is pushed far enough forward but his just springs back to neutral. I am thinking maybe there is a ball detent issue here but am unsure. Does any one have experience with this? Thank you.
dbeam
07-16-2014 23:43:41
 Re: Case 2090 Float Control in reply to dbeam, 07-16-2014 15:17:53
I don't think the travel is the problem because while I was looking at it I took the valve loose from the linkage and tried pushing it to its max and never got it too hold.
4435
07-16-2014 19:24:36
Before you spend any money make certain the travel is correct. Had a 2090 years ago every so often the bracket down in the console would bend. Finally made a brace to the floor, problem solved. Tom
dbeam
07-18-2014 16:58:16
 Re: Case 2090 Float Control in reply to 4435, 07-16-2014 19:24:36
Could you tell me on your 2090 would float mode lock in place and if so would it do it regardless if the tractor was running or not? I am trying to figure out what is suppose to hold the valve in float. Thanks.
Copyright © 1997-2015 Yesterday's Tractor Co.
