TractorLinks.com
Show Parts for Model:
Re: CASE 310E 1957 Loader / Transmission slipping
Case Nutty 1660
07-16-2014 13:45:47
I will say you have a wheel tractor and not a crawler tractor, wheel 310's use 80wt-90wt in the rear end and the current oil I recommend is Case Hy-Tran for everything but the engine, I also use this in my rearend/trans compartments rather than the 80-90wt, costs more but to me its worth it, the "GL" oil is for the rearend/tran on a 310 crawler due to the steering brakes, any Case construction dealer can get you the books you need as well
cnt
Bobalounj
07-16-2014 14:03:11
 Re: CASE 310E 1957 Loader / Transmission slipping in reply to Case Nutty 1660, 07-16-2014 13:45:47
Yes it is a wheel tractor with a front loader and backhoe, Thank you for the info on the proper type of oil to use. When I drain from just the transmission, do I get all the oil out or do I also need to drain the rear to get it all out.
Thanks again
Bob
Case Nutty 1660
07-16-2014 18:23:49
 Re: CASE 310E 1957 Loader / Transmission slipping in reply to Bobalounj, 07-16-2014 14:03:11
I do not have my book out but there should be at least two on the trans/rear end, and one for the torque tube/hyd,
cnt
Bobalounj
07-17-2014 10:04:35
 Re: CASE 310E 1957 Loader / Transmission slipping in reply to Case Nutty 1660, 07-16-2014 18:23:49
Quoting Removed, click Modern View to see Thanks Case nutty, For my own knowledge, what type of shuttle trans do I have?
Case Nutty 1660
07-17-2014 12:57:47
 Re: CASE 310E 1957 Loader / Transmission slipping in reply to Bobalounj, 07-17-2014 10:04:35
it is called a "8 speed shuttle trans"
cnt
Bobalounj
07-30-2014 05:53:58
 Re: CASE 310E 1957 Loader / Transmission slipping in reply to Case Nutty 1660, 07-17-2014 12:57:47
Hello Case Nutty, If you don't mind I have a couple more questions.
I found 2 drains, 1st one is a 1/2" drain under the gearbox, and a 2nd one is a 3/4" drain under the differential. Where is the 3rd drain for the torque tube?
Where do I refill them? Do I just use the single fill hole near the dip stick on the main gearbox? or are there multiple places to refill?
Thanks in advance
Bob
