need wiring diagram and gov. spring for case 300 or 310
roger8244
I need to know if anyone has a wiring diagram for 1956-1957-1958 case 300 or 310 tractor? And governor spring for the same tractor, I have had no luck finding ether one online.
Roger
The governor spring is available through any Case Ag or Case Construction equipment dealer. The original part number was VT4588, which now subs to A30572. Last time I bought one it cost about $17.
Thanks for the wiring diagrams.
as far as the gov spring....I found out that the carb was changed and the throttle mount was wrong so I made a bracket and attached it to the carb and it works great...
