TractorLinks.com
Show Parts for Model:
Re: Case 442 (little guy) ignition question
Firemanjohn
07-15-2014 18:38:23
On the timing issue, help me think this through. I did the ether, my way of checking fuel, since anything will try to run on that stuff, and there is no sign of life, I would think there would be enough residual ether to at least give me a back fire. I also put a little gas down the hole, also leading me to think if I have fuel, it is not being lit. My old timer friend had this Frankenstein spark plug with a huge gap which he said made sure the spark was strong enough to work under compression. So far the condenser sounds like the cheapest and easiest hunt and peck fix. Any other things I am not thinking of? And thank you everyone. This is why I love this board.
mEl
07-15-2014 20:15:25
 Re: Case 442 (little guy) ignition question in reply to Firemanjohn, 07-15-2014 18:38:23
The points setting is the only way to vary it's timing as the pushrod runs off a special lobe on the cam.
Back in the day of points style ignitions on multi cylinder snowmobile engines we would use a dial indicator with a special adapter in the spark plug hole to set points opening to a specified amount of thousanths BTDC. On multi cylinder engines the other set of points gap was tweaked to synchronize the timing
If you have excessive sparking across the points as they open I would suspect it as it's job is to absorb the spike of voltage at points opening and then release it back into the coil to intensify the spark, this can be observed on a oscilloscope as a wavy declining of the spark waveform. It should keep sparking at the points to a minimun and a well matched condenser will minimise pitting of the point surface.
Keep us posted, It also could be a coil issue so good luck sorting it out. I assume you have installed a new plug as a fouled plug will often fire the gap in open air but fire down the insulator under compression.
This post was edited by mEl at 20:16:51 07/15/14.
firemanjohn
07-16-2014 04:26:08
 Re: Case 442 (little guy) ignition question in reply to mEl, 07-15-2014 20:15:25
Thank you so much. Today is the basic tune up. Points condenser plug. I have never had one stall from running like this. Usually there is a period of hard starting or poor running first. It is unusual to me.
Clayton Spencer
07-16-2014 08:39:28
 Re: Case 442 (little guy) ignition question in reply to firemanjohn, 07-16-2014 04:26:08
I feel like it is a timing problem, my Dad had that with his 530, many moons ago. One other thing, I understand that you had just filled up, so I would think that a bad batch of fuel could also be the problem. I am just saying.
