TractorLinks.com
Show Parts for Model:
Re: Case 442 (little guy) ignition question
mEl
07-15-2014 18:16:17
[quote="C Kain"](reply to post at 17:41:37 07/15/14) [/quote
If the spark is not bright blue and will not jump a 3/8 gap I would suspect a coil or condenser issue. The timing on that engine should not be dependant on flywheel position as it has points that run off a points lobe on the cam. Also is the cranking voltage staying up while you crank it, if the voltage to the points is low weak spark will result.
mEl
