Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Case 442 (little guy) ignition question
T Whalen
07-15-2014 17:28:12
I have had Kohler and Briggs engines do this to me in the past and if all else fails put in a new flywheel key as the old one could be tweaked even a half of a millimeter throwing off the timing.
C Kain
07-15-2014 17:41:37
 Re: Case 442 (little guy) ignition question in reply to T Whalen, 07-15-2014 17:28:12
Hi, I run a 69-442 PK almost daily. but that doesn't help you, huh !! Anyway I think T Whalen has a good point. timing. Can you match the 'air thrust' out of plug hole. (compression) with the spark caused by the opening of the points. Right when it sparks, should be top-dead-center of the piston. (close) Or check timing by the book.
