I have been getting the 830 Case O Matic ready for pulling, turned up the fuel for a little smoke, added a couple front weights, 5 inch straight pipe, and a couple weights out back on the eagle hitch. I Pulled with it about a month ago just for a test, in third low in torque converter it will pull the front end of the ground about a foot. It seemed to pull good in both torque converter and direct. Is there anything I should be careful of when pulling with the Caseomatic other than watching the oil temp and letting off the throttle a bit when shifting to direct. Should I let off the throttle a bit at the end when she lugs down in direct to go back to the torque converter or just stay on the throttle and pull the lever back to the converter? I always let off the gas when shifting from torque converter to direct when going down the road. Any advice is appreciated
Thanks
Ben
Thanks
Ben
