Case Model 380 Tractor
Anonymous-0
Hi there, I was wondering if anyone could help me
figure out what type of oil a J.I. Case model 380
tractor uses? I've been looking all over the place
but haven't found a lead. Any help would be
appreciated, thank you.
If it's a gasoline engine and you run it only in the summer, I would use SAE 30 weight. If you use it year-round, I would use 10W-40. Any brand of oil made for automobiles should work.
the engine will be fine with 15wt-40wt- heavy duty dsl engine oil I prefer Case oil, you may also use the same in the rearend/hyd system or my choice I Case Hy-Tran hyd oil, the power steering also use Hy-Tran
cnt
