830 CK Operator's Manual
oldproudvet
Any one out there have an operator's manual for a 1965 830CK? Swap sell barter (first born is still available) I just picked up '65 8sp for the farm and can't find one thru "normal" channels, lit dealers I know, ebay etc etc. Several minor questions that are best addressed with manual. Serial #8274836. Thanks
you are talking a "CK" model with Draft-O-Matic or a Eagle hitch one? I have several extra Eagle itch ones but no "CK" if its a Eagle hitch one be glad to send you one, thanks again for th ones you sent have not forgot you just been tied up haying, will get square with you soon
cnt
Thanks! This is a diesel. My ol 400 showered me in antifreeze last weekend while mowing, in the farm scheme it mows, the SC combines windrows and flips when it gets washed (to common this year) and the 1070 turns the baler. It was really neat, not a spit but a gush up and out the muffler. Shut it off to check out, and then it hydrauliced when I hit the starter. I suppose the ol girl had swallowed enough diesel over the years and a head gasket let go. But I've still over a hundred acres to put up and that size was needed. I cut a bit with the 1070 but its to heavy to be running over the hay ground for mowing and baling. This came along as a really nice original tractor priced right so it's in the yard as of last evening.
