Atlast, I did not get any Wrinkles!
1370rod
After 25 yrs. of installing a occasional cab kit (maybe one a year). I finished without getting a wrinkle. I think this calls for a cold one, LOL. Rod.
Rod,
That looks great, I have to do the cab in my 1570, what kit did you use? What do you use around the firewall on the 70 series? I think you deserve more than one cold one.
Ben
Bet thats a Fells interior. Origional supplier. Suggestion on differential lock. I would remove
the little foot thing on valve cause if you ocasionally carry stuff on floor it will not get under pedal.That will remove chance of just getting differential valve not fully engaged an i always thought that might protect from slipping an damaging facings.
Several suppliers as you know and I am sure they all do a good job, I have always done business with Fehr Cab of IL. For the 70 series firewall I use a mylar faced foam 1 in. thick and tape all cuts and seams with aluminum tape. Rod.
WOW! Rod that's a first class job. I need a cab kit for my 1370 but I have been waiting until I could figure out how to install a kit the right way.
Do you sell these kits?
I read in a lower comment something about using mylar insulation for the firewall, what needs to be done to install that in the firewall
Hey Rod,
You did a really nice job there, but sorry, I beat you to the B pops cooler, as I got rained out on my landscaping job across the road, at my dads house. I will post some pics later. didn't have a lot of rinkles in the mulch either.
Loren
Yes I do sell the kits but you can purchase them also. If you need help to get one I would be glad to help. Mylar is a heat reflective material with sound deadening foam. It is great on firewalls and is more weather resistant than the plain stuff. To do a good job on the firewall the tractor needs to be split but a fair job can be done without splitting. It is not a fun job, but done carefully it is well worthwhile ending up with a cooler, cleaner and quieter cab. Rod.
