karl h
Today I was baling in 2nd range 3rd PS. The tractor
stopped without warning. The PTO, 3 pt and steering
still work, however nothing happens with inching
pedal pushed and I can put it en every range without
using the inching pedal. The tractor does not move.
Any thoughts?
Sounds like classic torque limiter if the hydraulics are working.
That is the most common but have heard of drive gears coming off the transmission shaft on some other models.
mEl
I wouldn't rule out electronics. First check fuse panel for for blown fuse. Two of solenoids on control valve should be activated in any range and are magnetized. With tractor running in neutral see if a small flat washer (3/8 or 1/2) will stick to two the four solenoids. email is open
I found the trans fuse blown and have replaced it. The tractor now moves in every range; however i have NO power shift or reverse. Also when i let the inching pedal out i cannot feather it the trans just slams in (very Jumpy)
So it moves in 1st PS now? Check that the clutch pedal micro switches aren't sticking. Then I would replace the PS board in the console.
