Help With VAC seat springs
connor9988
Location
Central Iowa
I have the stock VAC seat and I'm not sure how the
seat springs are supposed to be set up. I don't
believe mine is right. Can anyone post some pictures
of what it should look like? Thank you
The stud that your spring is on it to keep the seat from coming up too far. There should be a carriage bolt in that slot and you slide it with the spring forward or backwards to adjust your tension. Not the first time someone has put it there.
