eMl
I adjusted the c3 retard adjuster slightly but there was no change when pushing the clutch in when cold. Tried more than one position w/adjuster screw but there was no change. Put the adjusting screw back where it was originally. Tractor still stopped fairly quickly when pushing the clutch in when cold no matter where the adjusting screw was. There is a clank when power shifting from 3 to 2 in 3rd range but it does shift good & in every range & every power shift gear. Tractor stops normal when oil is warmed up. Is the clank something to worry about?
Thanks,
Dennis
Thanks,
Dennis
