I finally managed to get the loader mounted on my 830 lp. It took some serious engineering to make mounts to make that John Deere loader fit. It turned out to fit the old girl pretty well I think... but I got a big surprise as far as operation!!! I set it up to run off the tractor remotes and it is SUPER FAST!!! Apparently that Case pump has a lot more flow than I thought!! I am going to have to put some restrictor fittings in to slow it down a bit.. I am also having an issue wit one of the tractor remotes. It works perfect in one direction, but is really slow and wont hold pressure in the other direction... I am gonna have to dig out the book and tear into that valve eventually.
