Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Unknown Model Number
Robert Laurin
04-30-2014 15:51:26
Thank you all.
I am told by its owner that when he bought it he was told shaft was broken and removed that runs hydraulic pump and PTO. He also states some of the drive gears do not operate as if they are missing from the transmission. My guess is hydraulic pump drive shaft missing causes these other gears to not work. Would this be a safe assumption? Parts are missing?
Don Rudolph
04-30-2014 16:43:33
 Re: Unknown Model Number in reply to Robert Laurin, 04-30-2014 15:51:26
Anything is possible but, there is the small option that the previous owner simply did not know how to shift between ranges and so could only "find" 4 gears instead of 8. Hopefully that's it. Maybe someone else could post a shifting diagram for you. It can be confusing until you get it a feel for it. I apologize in advance if you already understand how the shifting works. Don
Chuck Machinist
04-30-2014 16:23:41
When you decide to get into her ,do not hesitate to make further inquiries . I got into my hydraulics last fall, and found moisture contamination, and I was fortunate only to drain the system and change the filter and refill. There is a wire mesh filled cap that wasp like to plug up with mud, just remove it and wash it in a can of solvent. Your going to have fun discovering her idiosyncrasies. John Saeli has the filter you need. His # is 315-585-9826 Chris, his better half will easily fill your order , as she says-he is putting out fires .She keeps the fire extinguisher close by! HEE! Chuck Machinist
