Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 400 super diesel hydraulics
EliG
04-30-2014 15:25:40
Another thing to check would be the orings that seal the pump to the tubes that go down into the hydraulic reservoir. They get old and can crack allowing the pump to suck in air.
The tube in the reservoir has a screen on the end of it. It may be plugged with debris. You can check that by dumping the oil and removing the cover on the filter and the filter. The filter is on the back side of the reservoir on the right side. It has 3 bolts with a pipe plug in the center. The filter can be cheaned and reinstalled assuming its there.
Some folks will add a quart of 85W-140 to the oil to help deal with wear in the pump.
Good luck.
Eli
CountryCase
04-30-2014 19:27:04
 Re: 400 super diesel hydraulics in reply to EliG, 04-30-2014 15:25:40
I pulled the filter. The screen wasn't plugged but the oil was BAD dirty. I will give the heavy oil a try. I will take it apart this summer to check the O rings. I have it on a disk right now an don't really want to take it apart unless its a must. Thank you for the info
