TractorLinks.com
Show Parts for Model:
830 rear end
NC Kelly
04-29-2014 20:22:40
I'm looking for an 830 case transmission/rear end. I believe a 730, 930, or 1030 rear end will also work.
Paul A Young
04-30-2014 07:35:33
 Re: 830 rear end in reply to NC Kelly, 04-29-2014 20:22:40
Where are you located ? I have a complete tractor . Cheap !
Jllw
04-30-2014 07:15:08
I have one here in central ky 606-303-0891
Eagle Doc
04-30-2014 05:05:38
I have a 830 Eagle Hitch transmission/rear end and I know of a 730 Comfort King for sale. My email is open.
NC Kelly
04-30-2014 07:51:06
 Re: 830 rear end in reply to Eagle Doc, 04-30-2014 05:05:38
I'm in North Carolina. My situation is that my Grandfather bought an 830 with "right brake knocks" painted on the tire. The only trouble it ever gave was that it knocked when going down hill. Then, a few years ago, 1st gear went out. I only use it for mowing/baling hay, so it never really bothered me. This week, I opened the transmission to see what was inside, and found that there had been a bearing failure on the lower shaft, and everything inside has been chewed up. :shock:
1031D
04-30-2014 08:04:54
 Re: 830 rear end in reply to NC Kelly, 04-30-2014 07:51:06
I think you can use anything 400-830 with the exception of the 400 not having speedo drive parts
harely
04-29-2014 22:12:38
my books came right from case case 830&730 are different from the 930&1030 they show a good breakdown of what you needbut part#s are different
INCase
04-30-2014 09:17:47
 Re: 830 rear end in reply to harely, 04-29-2014 22:12:38
they are different. but if you were crafty you could bolt the 730-830 motor to a 930-1030 rear end.
Tin and steering may be a trick to do.
NC Kelly
04-30-2014 07:40:17
Thanks for that info. I've got a parts manual for the 730-830 and shop manual that covers up to a 1030, and was hoping since they are grouped together in the shop manual that they used the same housing.
Chuck Machinist
04-30-2014 02:06:03
Would the 400 series tractors a possible choice? Chuck
NC Kelly
04-30-2014 07:41:00
 Re: 830 rear end in reply to Chuck Machinist, 04-30-2014 02:06:03
I don't know if a 400 series would work or not, but if so, that would be great!
This post was edited by NC Kelly at 07:52:54 04/30/14 2 times.
