Hello there.
I was using my 930 this winter it purred like a kitten till I shut it off in March. after the next snow fall I tried to start it . it poured out smoke heavy as it did before I added fuel conditioner early in the fall. it ran beautifully all winter till March and the no start . Now it seems to not be getting any fuel at all, it is even hard to crank over. I'm told this is because it is dry, no fuel I have bought new fuel filters and will now install them when weather improves. I do not think anything has broken as it was ideling nicely when I shut it off. The plunger on the front of the injector pump is moving freely
I have tried to bleed it before this I think I have fuel to the 3d filter. But please tell me how do you bleed the injector pump.After bleeding all 3 filters the primer pump can be pumped 6 more times before there is pressure. My tractor is a Comfort King 1967 I have also checked the throttle linkage it is fine also. I,m hoping all this is because I've lost the prime
