serviceair filter
axe55
I have a 930 case manual on cd... . I couldnt find the answer...How do i clean/service the air filter? Is the filter inside the canister removable?( Sorry pic needs rotated) Thanks john
You have an oik bath air cleaner. There is no replaceable filter element. Empty the oil and clean all the dirt from the bottom of the cup. Fill to indicator linr with engine oil and reinstall.
Gene
Gene, thanks I thought there was more to it. I cleaned the pan and replaced the oil......Would you or others members know if the I&T Manuals are more user friendly than the case manual ? Thanks again john
If it looks like there is a build up of debris in the filter element, I have removed the entire filter housing and flushed them out with gasoline.
C. Amick, the filter looks real dirty 45+yrs. Im going to take it off and soak it. thanks john
