Installing a Prescreen on 12-1370's with Air Induction
1370rod
On early air induction units this neck has to be removed, a hack saw works fine. Later units do not have the neck on. The 6 in x 6 in 90 degree rubber elbow can be had from truck part store. The prescreen itself I do not think is available from CASE anymore, I have always been able to get them from the local salvage yard. Same thing a 1570 uses. Now after some careful measuring and cutting to get the hole in hood correctly and some moulding you can have a neat finished job that looks factory. Happy Farming, Rod.
