Raphael Schumacher
New User
I have a 2590 witch is having power shift problems.
1st it was stalling out when I put the clutch in. All the symptoms I had, I read about on this forum, so I pulled the front spool on the valve body and cleaned it out. This solved that problem. All 4 gears work in 1st and reverse on the power shift, but 2nd and 3rd seem much like 1st.
Then I took the valve body off and cleaned all spools, I changed the hydraulic oil and filters ,while I was at it, but it still acts the same after I put it back together.
Is this a bigger problem? Can anyone give me some advise?
Thanks Raph S.
Thanks Raph S.
