pressure test equipment
rndy3788
I am wondering if anyone has available or knows where there may be the test equipment (to buy or rent) to pressure check the clutch pressures for 90/94 series tractors , The closer to se mn the better, the local dealer doesn't seem to be real interested in these tractors , so I thought I might just go at it myself, thanks
A single 300 psi gauge with a short hose with 1/8 pipe thread on the end is all you need to pressure test those tractors. With a single gauge it takes a bit of time, but to be honest most of the time that is all I use. Rod.
