case 1175 leak from pto output shaft
Mark Stintzi
New User
I have a seeping leak coming from around the pto shaft on the 1175. From what I understand from the parts book it could be from the bearing and oil seal retainer or from an o-ring on the output shaft sleeve support assembly. It appears it is the latter as the leak is coming from the inside where the pto shaft sits. Am I understanding the two possibilities correctly? And if the problem is likely from the o-ring, how do you get to it--from the outside through the retainer or from the inside taking the pto housing off? Thanks, Mark.
