water in engine oil
My 42 D is getting some anti freeze in the crankcase. Naturally I drained the water. I'm guessing head gasket or probably sleeve O Ring? Not getting a lot of water in oil but if you leave it parked it shows up. Any ideas short of pulling the sleeves?
you could remove your inspection covers from oil pan and try to inspact the bottom using of sleves with merror. i had a simelar problem with a dc and it ended up being one of the o-rings
I would first try adding some some block sealer to the cooling system. Some of it works with water and some of it will work with coolant.
I can't seem to locate the stuff that I used before. I think they have changed the formula. I believe it was a Bar's product.
