Nebraska Tractors Arrive in Minnesota
1370rod
The 1370 I purchased from a online auction service early in Feb. It is a low hr tractor in seemingly pretty good condition, decent rubber and appearance. On a 1-10 scale I would call it a 7.5, I hope to check it over and service it before finding it a new home with one of my customers. I am certain the hrs are not correct, but it does show less wear and tear in the normal places than the average 1370 around here. The 2090 hitched a ride on the same truck and comes to me to be repaired as it had the misfortune of having something fail in the 3 pt hitch lift cancelling linkage. This caused the internal parts to go to far and damage trans and PTO housings. Ouch! Will be quite a summer project. Will post more when I get the opportunity to work on these two tractors. Rod.
Doesn't look like they are homesick for ne yet!We ended up with 2 inches of snow this afternoon. Slushy,sloppy mess.But the moisture is very welcomed.Back in the mid to late 70's lots of jd[and other brands] would buy the 70 series to do their heavy tillage work.I always thought a dualed up case tractor working away in the field was the coolest site ever.Ole to the good old days!
Rod, where are you located in Minnesota? I live between Cambridge and North Branch. Nice looking case power there!
Rod, They look like clean tractors, something nice to start with at least. I have a ugly 2090 with a trashed PS, maybe we should talk.
Eric, there will be another 2090 headed this way from Neb. as a parts tractor for the housings. When all is done we will have to compare notes and see what is left. Maybe enough to bring another one back to life. Rod.
