970 CASE OIL PUMP SEAL
Jim Grimm
My neighbor took the main bearing cap off of my 970. Had to take the oil pump off first. When he put the oil pump back on,he nicked the O-Ring up. He said it is hard to slide in without damaging it. Is there an easy way to slide the pump on without tearing the O-Ring? Also it shows on the case ih partstore that the O-Ring A6443Y is no longer available. Would appreciate some info. THANKS
Use a strip of shim stock no more than .005 thick to cover passage in block and pull out after pump is in place.
Jim, Is Bruce going to have your 970 ready for spring work? Might be well into May before you need it with all the rain we had today. Al
