2390 remote
GlennMc
New User
2390tractor,number 2 remote does not work at all.Have taken
it to shop twice.Number one works fine.Control cables free&
adjusted properly,hose ends on tractor & implement
changed,adjusted valve flow control still nothing.PLEASE
help,,!!!!
Secondary shuttle valve IN #1 remote is bad. The only plug on back/trans side of remote valve and has a screw driver slot to remove. Impact driver works good to remove. Each valve has a primary and secondary shuttle valve needed for load sense with PFC hyd's. The Primary shuttle valve will affect the valve it's in while the secondary will affect the valve down stream as in your situation. Secondary can be removed after valve stack is removed but not separated.
