Need HELP with a CASE DI
I"m working on a Case DI 45 model. Serial # 4913341. How do I find the line card or can you look it up? There is red under the yellow paint but I can not tell if it is original painted color or primer? Looks like the same color inside the housing behind the clutch inspection plate. Also need to know how do you take the brake & clutch pedals off? Do you know if this tractor only has one brake pedal.
Your DI is a 1945 year mocel. You should get someone on here to commrnt on the brake pedals. My 42 D has two brake pedals. One on each side by your feet and it has a hand clutch. You can contact Tom Railsback in Great Falls, MT. on D questions. He asnwers Tecnical questions for the Old Abs News magazine on D series tractors. [email protected] He might tell you where to check on the line card. Not all line cars are available. Dick Benson
