CASE DI 45 MODEL
I"m working on a Case DI 45 model. Serial # 4913341. How do I find the line card or can you look it up? There is red under the yellow paint but I can not tell if it is original painted color or primer? Looks like the same color inside the housing behind the clutch inspection plate. Also need to know how do you take the brake & clutch pedals off? Do you know if this tractor only has one brake pedal.
