CASE 311 PROBLEMS
Anonymous-0
I have a Case 311 I'm restoring and I was looking for a throw out bearing and also was wondering what the paint code is for like the hood and fenders I ordered power white but people have been saying something about desert sunset paint if so where do I get that
Thanks
-Isaac
See your CaseIH dealer for paint. You can replace the bearing that is in the throw out bearing assembly. You should not have to replace the whole thing. Maybe joe has a picture.
I"ve only tried taking one apart, wasn"t successful. Besides the notch seems to be either worn down or all the way gone.
300"s are easy to split but I prefer to bite the price bullet and get done with it.
Single plate clutch T/O brg is p/n G10610. Last I bought about 3 yrs ago $97 each.
If you"re going to attempt to take it apart, read this post.
Joe
Throwout brg
Isaac, just saw your post on the Restoration forum. Good luck with your FFA project. I did a valve job on our '47 VAI when I was FFA, course that was back in 1958, about a year or so after your tractor was built.
Flambeau Red and Desert Sunset paint is correct. Rims may have been silver color, not sure. Someone here will know and may be able to provide the paint codes or you can buy it from Caseih.
Pictures are very helpful when you need some info or a part. Go to the link, in the model box type 300. You want the (300-SERIES) - CASE WHEEL TRACTORS (1/56-12/57) section. Find the part name and number so we have a better idea what you need.
Joe
http://partstore.caseih.com/us/midsouthagsumner/parts search.html epc::model_find
