The 1370 CASE
1370rod
If I could only keep one of my tractors to farm with, this would be my choice. It performs well for most any job. A simple well built powerhouse that are relatively inexpensive to own and operate. I would have to install 18.4x42 rears for row crop work. Rod.
Hi Kurt, the pic was taken at about 10 min before sundown on a cloudless eve. The lighting is different but kind of cool, Rod.
It is for a 1570, I always felt these tractors lacked enough screen area. The front grill would plug easily with corn leaves in the right conditions resulting in a high vacuum in front of the radiator. This caused them to pull in leaves through every little crack in hood panels which would cause the radiator to become plugged and plug the air induction system if it were not equipped with the hood prescreen. What you can not see is the screen I install on the top of the hood leading into the radiator area also, all these little changes have helped minimize cooling system cleaning a lot, and vastly improving engine cooling under adverse conditions. Rod.
I know I would be lost without my 1370.
Rod what size of disc are you pulling?
I am pulling a 21'-1/2 ft 48 IH disc with wing extensions that makes it 22-1/2 ft on back.
