Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
The 1370 CASE
1370rod
04-02-2014 19:47:16
If I could only keep one of my tractors to farm with, this would be my choice. It performs well for most any job. A simple well built powerhouse that are relatively inexpensive to own and operate. I would have to install 18.4x42 rears for row crop work. Rod.
Brokengun
04-03-2014 08:29:08
 Re: The 1370 CASE in reply to 1370rod, 04-02-2014 19:47:16
I know I would be lost without my 1370.
Rod what size of disc are you pulling?
I am pulling a 21'-1/2 ft 48 IH disc with wing extensions that makes it 22-1/2 ft on back.
1370rod
04-04-2014 10:13:10
 Re: The 1370 CASE in reply to Brokengun, 04-03-2014 08:29:08
I have a 20 ft, got that when the 970 was my big horse. Wish I had a 24 ft. Rod.
Don Rudolph
04-03-2014 06:41:36
Rod,
That is a great picture! Any reason why you would take a 1370 over a 1570? Just curious. Don
1370rod
04-04-2014 10:03:32
 Re: The 1370 CASE in reply to Don Rudolph, 04-03-2014 06:41:36
Don if I had a 1570 that would be my fav, Rod.
Mike from Wisc
04-03-2014 04:09:01
Rod the top front grill screen did she come that way or is it out of a 15?
1370rod
04-03-2014 05:44:24
 Re: The 1370 CASE in reply to Mike from Wisc, 04-03-2014 04:09:01
It is for a 1570, I always felt these tractors lacked enough screen area. The front grill would plug easily with corn leaves in the right conditions resulting in a high vacuum in front of the radiator. This caused them to pull in leaves through every little crack in hood panels which would cause the radiator to become plugged and plug the air induction system if it were not equipped with the hood prescreen. What you can not see is the screen I install on the top of the hood leading into the radiator area also, all these little changes have helped minimize cooling system cleaning a lot, and vastly improving engine cooling under adverse conditions. Rod.
Kow Farmer
04-02-2014 20:16:48
Awesome picture Rod. That is Case calendar material for sure.
Kow Farmer Kurt
Chuck Machinist
04-04-2014 16:06:57
 Re: The 1370 CASE in reply to Kow Farmer, 04-02-2014 20:16:48
I concur .To the calendar it should go. She is B.A.
1370rod
04-02-2014 20:40:41
Hi Kurt, the pic was taken at about 10 min before sundown on a cloudless eve. The lighting is different but kind of cool, Rod.
JohnDy
04-03-2014 09:27:33
 Re: The 1370 CASE in reply to 1370rod, 04-02-2014 20:40:41
We better see that one in the calendar!!!!!!
Ronald in NWMO
04-02-2014 20:12:05
Beautiful picture. That's a great angle to take a shot from. I have never thought about doing that. Thanks for posting!!
Copyright © 1997-2015 Yesterday's Tractor Co.
