Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
7110 magnum trams problem
Dalton George
04-02-2014 18:58:20
My 7110 magnum 18 speed full power shift is stuck in high range and won"t come out. I can move it from park to forward but I have no low gears same in reverse. Full speed in reverse is not very safe!!
Any ideas what is locked and how to fix it?
Dalton George
04-04-2014 12:33:44
 Re: 7110 magnum trams problem in reply to Dalton George, 04-02-2014 18:58:20
Pretty sure it's warmed up enough now that if it was a cold issue it would be gone.
Dalton George
04-04-2014 10:34:07
Agri King
04-03-2014 05:23:31
If it is anything external there may be a problem with the forward-neutral-reverse cable (worn cable or linkage) perhaps. The clutch & FNR cable ends are covered by a tower at the valve. You need to determine which is which. DO NOT go adjusting the clutch cable. This sets trans. pressure. The trans. is divided into 2 sections, speed & the range. If you are not experienced with these tractors you may be best off to have your dealer check it out.
Brian Stortenbecker
04-02-2014 20:25:03
What gears do you have, the range trans consists of low, med and high clutch packs.
Brian Stortenbecker
04-02-2014 20:45:30
 Re: 7110 magnum trams problem in reply to Brian Stortenbecker, 04-02-2014 20:25:03
High range is 13 thru 18, so I assume if low and medium do not work, it may be in the control valve. Did this happen all of the sudden?
Dalton George
04-03-2014 07:56:22
 Re: 7110 magnum trams problem in reply to Brian Stortenbecker, 04-02-2014 20:45:30
Ya all if the sudden. I started it one day this winter, let it warm up and pulled it out of park and put it in reverse and it was in full speed reverse. I moved it into forward and the same thing high speed. Not sure what exact gear it goes into but it is definitely in high range. This happened a few months ago when it was cold so I just parked it and used my other tractor till now and it started to warm up.
Brian Stortenbecker
04-03-2014 16:33:05
 Re: 7110 magnum trams problem in reply to Dalton George, 04-03-2014 07:56:22
Cold weather can cause a lot of weird things. If it were me and it started all of the sudden, I would either get it in a warm shop or wait till it warms up. Or get it on a Dyno to warm the trans fluid up and then try.
Dalton George
04-05-2014 07:22:51
 Re: 7110 magnum trams problem in reply to Brian Stortenbecker, 04-03-2014 16:33:05
