Case 2470 Hydraulic Pressure
I lost considerable pressure to the remotes on a 4890, which is very similar to your 2470. I discovered that when I engaged the PTO, I had full power to the remotes again. Turned out, the problem was w/ the PTO brake. I disconnected the line running from the small valve in the back to the PTO brake & the problem was solved. Later I removed the shaft.
