400 radiator.
EliG
It appears that the radiator on my 400 diesel needs some help. I had it boiled and tested when I overhauled the engine. Put it in the tractor and it leaks. Took it back to the shop and had it tested again and was told it doesn't leak. I pressure tested it and found that it leaks where the cores goes in the top tank. I also suspect that cores are leaking as well. Does any one know of a good radiator shop in central Iowa or maybe have one that they would be willing to sell? I don't believe a new one is available.
Thanks,
Eli
