Anonymous-0
Hello guys,thanks for reading. My 2290 powershift here has an issue im hoping you may have seen before. It is very hard to shift into first and second gear. I mean i really have to push. It will go in and gears work fine and everything works as it should but just hard to get it there. This tractor is well cared for and has good clean hytran and regular filter changes. Has about 3600 hours on it. I did remove the black cover in the cab and lubricated what i could down there while i was in there because i had to replace the fuel shutoff cablebut i think its beyond that that quadrant has plastic bushings in it anyway i believe. I sure hope i didnt bend something inside. I have used it this winter to blow snow with and one cold morning it started this. One day fine, next day not. What you think??? Thanks so much
