Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1370rod,Agriking,mEL,others help?
1370rod
03-29-2014 20:58:51
Have someone try to shift it in and out of those gears while you go and watch on the RH side of the trans behind the front area of the rear tire. You will see the shifting linkage moving up and down moving a shaft going into the trans. Lubricate the shaft with a penetrating oil where it enters the housing. After some use it should begin moving easier. The oring that seals the shaft is located in about a inch leaving a area were the shaft can get rusty inside making it hard to turn. You can remove the pin connecting the link rod to the shaft and then everything in the cab should move very easy confirming that it is the shaft getting tight, Rod.
Josh Kelnhofer
03-29-2014 21:05:16
 Re: 1370rod,Agriking,mEL,others help? in reply to 1370rod, 03-29-2014 20:58:51
Wow thamks for the fast response rod.I guess im not the only night owl lurking on YT! Yes i see that shaft and how it works> Ill try getting it lubricated and make sure its clean too. Thank you very much ill try to post back tomorrow
