TractorLinks.com
Show Parts for Model:
Re: A Mechanics Memories, All The 1370 Rear End Jobs.
Brokengun
03-29-2014 10:40:44
Rod if you've made a living splitting 1370's using hyd bottle jacks and a gantry crane then your a better man than I am.
When I split my 1370 I had a gantry crane to remove the tires. I the used a backhoe to set the tire/rims outside. A cherry picker for the rear axle housings. I had a homemade stand on rollers to split the rear end from the tractor. Hoist stands to support the cab. and a ton of blocking to support the engine.
I did it that way because my health is so bad I don't have the strength to wrestle the stuff around anymore
1370rod
03-29-2014 10:57:12
 Re: A Mechanics Memories, All The 1370 Rear End Jobs. in reply to Brokengun, 03-29-2014 10:40:44
I just role the tractor apart with a floor jack attached to the drawbar. I always remove axle and wheel as a unit. Have many little tricks that you learn through the decades. Easy job unless they have 42 in tires pushed up tight against the cab. Rod.
