Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
What model plow is this?
Mike Fitz
03-27-2014 14:35:33
I spotted this plow today and I'm wondering what model it is, and approximate date of manufacture. Mike
Bobl1958
03-28-2014 08:11:20
 Re: What model plow is this? in reply to Mike Fitz, 03-27-2014 14:35:33
It's an early "Green Axle" A series, like has been mentioned. If it is a 16" and has the newer EX wear parts on it they are still available. If it is a 14", or has the old CX "Blacksmith" shears and moldboards, they are no longer available so hopefully the shears and moldboards are good. You might still find some good used ones, but they are getting very hard to find. The A series are a little higher clearance, and certainly better made than the B, C, or G series. Still a very nice find. Good luck - Bob
Mike Fitz
03-27-2014 17:42:13
Wow guys, thanks for all the replies! I've seen C series plows before, but not an A series like this. This is a heavy built plow, other than the tail wheel is off(the owner has it) it is in good shape. I think it will be coming home with me soon. Mike
Case Nutty 1660
03-27-2014 18:05:41
 Re: What model plow is this? in reply to Mike Fitz, 03-27-2014 17:42:13
here is one pic I found I should have more
560farm
03-27-2014 15:05:45
Looks like an early A series to me with the green/orange paint scheme.
casecollectorsc
03-27-2014 15:32:14
 Re: What model plow is this? in reply to 560farm, 03-27-2014 15:05:45
Early C series had that paint scheme also. Think it's a A because of the same beams as a centennial. C series had side plates for plow beams.
Joe Young
03-27-2014 16:43:23
 Re: What model plow is this? in reply to casecollectorsc, 03-27-2014 15:32:14
I agree and the hydraulic lift assembly is consistent with an A series. It's not the C series setup. In addition, the bracing beams on the left side are consistent with the design of an A series. The beams on the "C" series are formed from flat stock.
My vote is an early 50's A series.
Case Nutty 1660
03-27-2014 14:54:14
looks more like a model "A" plow a early one at that with the color, late 50's, will find some more lit for you
Case Nutty 1660
03-27-2014 14:51:16
Looks to be a Centennial model, with Hyd lift it will be 1949 or later they were made into the mid to late 50's
Case Nutty 1660
03-27-2014 14:52:40
 Re: What model plow is this? in reply to Case Nutty 1660, 03-27-2014 14:51:16
WHOOPS screwed that up I missed the box frame that's not a Centennial, sorry will do more digging
casecollectorsc
03-27-2014 14:59:57
 Re: What model plow is this? in reply to Case Nutty 1660, 03-27-2014 14:52:40
Case C Series plows appeared in the late 50's. Built after the Centennial line. I think that what it is...
Adirondack case guy
03-27-2014 16:39:25
 Re: What model plow is this? in reply to casecollectorsc, 03-27-2014 14:59:57
My Case price books go from B/BH series plows dated March 1, 1956,to A/AH series plows dated 8/14/1956. Absolutely no mention of a C series plow.
Loren
Case Nutty 1660
03-27-2014 15:09:34
Steve I was thinking "A" due to the rail road iron frame will look and see if I have "C" lit thanks for the tip
casecollectorsc
03-27-2014 15:29:12
 Re: What model plow is this? in reply to Case Nutty 1660, 03-27-2014 15:09:34
I think you are correct on the A. Computer dumped and couldn't get back on quicker.
