830 comfort king lp production numbers Paul Young?
Hayrack
I was looking through some of the old posts on here about 830 LP's and I seen a older post where Paul listed how many were produced each year for the comfort king lp casomatics....Paul, does you or anyone else have the same info for the dry clutch models???
According to what I was given from a friend that got these #'s from Racine. 1965 did not specify lp #'s.
840C LP ;1966-1
841 LP ;1966-82,1967-73,1968-35,1969-15
842LP ;196619,1967-15
840LP ;1967-5
841C LP;1966-35,1967-24,1968-1
843 LP;1966-1,1967-11
843C LP;1966-1,1967-11
I don't know why LP was not designated in 1965 but I do know they were made that year. Hope this helps. Paul
I guess I should explain if you didn't know the C after model # designates case-o-matic.
840 = standard 4 wheel
841 = general purpose (NF or adjustable WF)
842 = western special
843 = high clearance
Thanks Paul... WOW, Less than a hundred for any model of any year! Hard to believe that they continued production of them with numbers that low.
I have 841C 8312538 with DB loader on it. I am the third owner. great tractor. I also did not realize so few were built. I also have a 1968 930 rowcrop on propane. curious how many of these were built?
Paul, do you have a listing on the following tractor? A 1957 C O M, gasoline, Comfort King, serial # 842 c o m, 8313543. I want to know how many were built. If you would like pictures , I can do that , as the tractor is in my back yard. I have the build card for it ,but no production numbers.
Thank you. clint.
Your tractor would be a 1967 according to that serial number.
842C are as follows:
1965-15
1966-6
1967-15
1968 and 1969 none
These are comfort king #s only. There were quite a few more 842's made with a dry clutch. About 302 between 1965 and 1968
941LP shows none in 1965 so I'm guessing they didn't designate between gas and LP that year.
1966-399
1967-161
1968-128
1969-111
