Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
611 ignition key, where to order one?
pcweber
03-23-2014 16:50:24
So I left the key in my stuff for years till one time a neighbor who never talks to me came by and could not find me but decided the key being in my skid loader and me not using it meant he could go ahead and take it and leave a note that he did. Anyhow, so I have been taking the keys out more. Well long story short now for the life of me I cant find the old key for the 611B. Are those old Case tractor keys all the same and if so, where can I order one?
pcweber
03-24-2014 15:58:16
 Re: 611 ignition key, where to order one? in reply to pcweber, 03-23-2014 16:50:24
no, that split key is not it. OK, may be time for a new ignition... or wait a little longer to run across it. Getting old, forgetting where I put things...
Dean Griffin
03-24-2014 14:45:09
This is the key to my Case 600B
1031D
03-24-2014 22:19:34
 Re: 611 ignition key, where to order one? in reply to Dean Griffin, 03-24-2014 14:45:09
This key is common to Massey stuff.
mEl
03-24-2014 15:12:08
That is the key , I am trying to import a pic from my cell phone but you saved me the trouble. We have the JD equivalent in stock. I have a Case one on my personal key ring. If the drawing is representative of the key he needs he does not have an OEM switch. Thank you Dean.
mEl
pcweber
03-23-2014 19:24:45
anther try at the pic... This look familiar?
This post was edited by pcweber at 19:25:48 03/23/14 2 times.
mEl
03-23-2014 19:40:27
 Re: 611 ignition key, where to order one? in reply to pcweber, 03-23-2014 19:24:45
If the key looks like that it is a non standard dswitch an all bets are off. The key for those standard switches were split down the middle with a little shallower cut at the back and the switch viewed looking at the face has 2 slightly bigger notchers at the edge for the two prongs to enter. mEl
pcweber
03-23-2014 18:22:53
OK, can now see it. No, that is actually functionally cut the same as the first one you posted. Mine is like an "F" with one side all flat.
PCWeber
03-23-2014 19:15:30
 Re: 611 ignition key, where to order one? in reply to pcweber, 03-23-2014 18:22:53
OK, here is my turn at drawing it from what I recall.
Case Nutty 1660
03-23-2014 18:40:45
is it curved if you look at it from the end? I am NO drawer but some thing like this?
mEl
03-23-2014 19:11:42
 Re: 611 ignition key, where to order one? in reply to Case Nutty 1660, 03-23-2014 18:40:45
G15470 should be the key number if the switch has not been changed out, you can look it up on Case ag parts and blow up the page and get a look at it. That is the key I recall for those tractors.
mEl
pcweber
03-23-2014 18:20:55
no pic/ cant see it?
pcweber
03-23-2014 18:00:50
Actually, if you mean split down middle that is not it. My Case key if I recall was like an "F" with both bars of the "F" being the same length, not a longer end bar and shorter middle bar. That make sense/ sound familiar?
Case Nutty 1660
03-23-2014 18:18:01
 Re: 611 ignition key, where to order one? in reply to pcweber, 03-23-2014 18:00:50
like this one?
pcweber
03-23-2014 17:43:36
Yes mEl, your description sounds spot on. thanks
1031D
03-23-2014 17:50:05
 Re: 611 ignition key, where to order one? in reply to pcweber, 03-23-2014 17:43:36
Mel's description is that of a common key to Massey also.
pcweber
03-23-2014 17:23:49
No, but that is just like my big mower and old IH skid loader key.
mEl
03-23-2014 17:37:21
 Re: 611 ignition key, where to order one? in reply to pcweber, 03-23-2014 17:23:49
IIRC most 611b tractors took the split type key with 2 prongs that fit into the switch, I think our dealership has new in stock as we stock most keys. The one shown is the "Indak" key and was used by numerous manufacturers and is common in new unit to this day.
Call 570 435 2921 and ask for Denny, explain what you have and he will look it up. Hopefully no one has transplanted a non standard or universal switch in place of the stock one.
mEl
Case Nutty 1660
03-23-2014 17:48:46
 Re: 611 ignition key, where to order one? in reply to mEl, 03-23-2014 17:37:21
that would have been the next one mEl thanks I could not think how to describe it
Case Nutty 1660
03-23-2014 17:17:24
does it look like this? it could have a different style as well
