TractorLinks.com
Show Parts for Model:
Re: Case 580 L backhoe wont go into forward or reverse
Case Nutty 1660
03-22-2014 10:10:48
did you check the convertor fluid level? that's the first place I would check, the 580L I had would burn out relays once in a while but not just from setting
Jeremy Williams newbie
03-22-2014 20:41:23
 Re: Case 580 L backhoe wont go into forward or reverse in reply to Case Nutty 1660, 03-22-2014 10:10:48
Could you please tell me how to check this. I've read so many posts and need a clear picture in my head of where this actually is. Thanks
Jeremy
Case Nutty 1660
03-23-2014 07:23:07
 Re: Case 580 L backhoe wont go into forward or reverse in reply to Jeremy Williams newbie, 03-22-2014 20:41:23
been 7 years or so since I had my "L" should be like my 580E though, on the RH side of engine around starter area should be a dipstick, engine off she will read over full, check idling with shuttle lever in "N" pull stick wipe off then reinsert and check, I use only Case Hy-Tran fluid, dipstick may have checking instructions stamped in it as well
