Nick 167 has a question
chuck machinist
I have posted this pic for Nick and he has a
question. here is your pic Nick
(quoted from post at 01:32:16 03/16/14) I have posted this pic for Nick and he has a
thanks chuck I really appreciate this. this is as far as I got it off and I cant get it any farther any help?
bt dt ,,. you mite be headaches ahead to unbolt the entire front bolster roll it out of the way and go at it with out havin grease ,oil ,filth , of all sorts dripping in your face ,, not to mention workin over your head , while it is out take a good look for cracked welds ,getting the cylanders out is one thing ,sadly the next headache is ahead ,, I assume you are wanting to install new seals,, fyi ,,there is a snap ring that is accessable only by removing elbow the hydro lines hook to
Thanks everyone I will try that and see if it will come off. And yes I need to replace the seals it leaks a straight stream of fluid out
it looks like the ball joint is still connected to the other end of the cylinder. thats gotta come out before the cylinder can twist off.
